Oil pressure /temperature sensor for Ms3
terryly
Post by terryly »
Hi there folks I am now wanting to datalog my oil pressure and temperature using my MS3pro ecu. Any one ever use the Lowdollar motor sports combo
temp/pressure sensors ? https://lowdoller-motorsports.com/colle ... -psi-500-f Are you logging to a stand alone ecu ? What brand sensor are you using ? Any advice ? I am also wanting to log pre intercooler and post intercooler intake air temperatures as well as the IAT sensor in the plenum and will probably just use the GM open air element sensors there. I don"t know if my MS3PRO will have enough inputs for pre/post intercooler tempsand the IAT sensor in the plenum. Need to do some reading in the manual.
Thanks for your thoughts in advance
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
panel
Re: Oil pressure /temperature sensor for Ms3
Post by panel »
I run this one for my fuel pressure.
https://lowdoller-motorsports.com/colle ... ure-sensor
I'm also running the standard GM open temp sensor. (only one though)
terryly
Post by terryly »
Thanks panel think I am going to bite the bullet and try out their pressure /temperature combo sensor. I have pressure and temp sensors installed for the Dakota Digital gauges that I have in the dash and they seem to a be real nice quality product that out put a 0-4.5 v signal. I toyed with just splicing their harness and splitting the signal between gauges and ecu. I was considering this route to avoid putting more sensors in the case. If I had to pick one I would pick the data logging over the gauges as the gauges are hard and unsafe to try and monitor while driving. I am interested if my oil pump pick up ,anti slosh plates and tuna can sump oil mods are doing their job or if the oil accumulator is supplementing the oil pressure during steep inclines or traversing hills sideways. I am hoping with data logging the oil pressure I will be able to detect a pressure drop and then a rise as the accumulator starts supplementing pressure. I have starved rod bearings with a 1- 1/2 " deep sump and no accumulator.
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
