Recently at Road Atlanta, in a LeMons endurance race, The EMPI straight cut cam gear failed in a way apparently different from the usual.
Typically, the large gear bolted to the cam breaks. In this case (and our first straight cut cam gearset failure ever) it was the smaller gear that slips over the crank and is held in position by the large Woodruff key. The gear weakened, and was about to split at its weakest point, the Woodruff key notch.
As the gear expanded toward separation, the gear began to rock and hammer the Woodruff key, actually deforming it. The cam, in turn, began to twist out of time, and the exhaust lobe for cylinders 1 and 3 struck the crank's counterweight and broke off part of the lobe.
Here's how our driver, the genteel Dr. Johan by day and the infamous (use your own judgement) Mr. Speed on certain weekends described it to the press. https://www.youtube.com/watch?v=-ofkMdVaUgg
There's no more to the story than this cautionary tale. Make of it what you will.
FJC (RetroRacing)
Straight Cut Cam Gear Failure
Re: Straight Cut Cam Gear Failure
Awsome discrption
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
- woodsbuggy1
Sorry to hear of your problems and thanks for sharing.
I was recently having a conservation with a 75yr old engine builder that commented how much more difficult straight cut gears are to remove from the crank compared to German gears. I have not had the chance to compare id measurements between straight cut and German gears but am now curious if the id is smaller on straight cut gears and possibly caused your failure.
Kenric
Kenric
https://carfromjapan.com/article/car-ma ... explained/
Or
http://automotivethinker.com/transmissi ... s-helical/
This might give you some ideas of the advantages of strait cut gears and the dis-advantages of them too when comparing about helical cut gears.
Or
- Max Welton
He is hilarious!FJCamper wrote: ↑Wed Dec 22, 2021 7:59 pm Here's how our driver, the genteel Dr. Johan by day and the infamous (use your own judgement) Mr. Speed on certain weekends described it to the press. https://www.youtube.com/watch?v=-ofkMdVaUgg
Max
- Clatter
FWIW, I've seen some affermarket woodruff keys that were dimensionally wrong.
They ended up being too big and made a tight spot on the gear.
Maybe that had something to do with it?
https://www.mechanicaleducation.com/202 ... tages.html
Woodruff key failure with straight cut gears is an old problem, the fit between the materials (tight or loose fit e.g., shock loading especially if the fit is off) and add to that the aging of the materials causing brittleness is, again, a very old problem. Straight cut gears can also be a problem with shock loading, if I remember again correctly, is an old problem.
