Since then it's been in my possession and I was asked to get it running but the more I dug the worse it got. The motor had .012 endplay, lifted heads and had been leaking for a long time. The brakes had plenty of shoe material left but everything else was trash. Electrical was also toast and all stripped and sent to the dumps.
So far I have rebuilt the engine(this is the block I line bored with my porta tool after I dialed it in on my test block seen here https://youtu.be/SNGsZpULOds ) I was able to clean up the stock crank, flywheel, rods, block and pushrods, everything else is new. I went with a stock displacement for the 73 block with aa pistons, jugs, and dp heads. Engle w100 cam with cb super stock rockers, single high rev springs with chromo retainers and keepers, new center intake and a "premium" 30 pict from aircooled.net. also upgraded to an alternator and bought a new tin kit thru aa performance. I will be soon testing out my engine run stand I recently built to break in the cam.
So far on the chassis I started in the front and bought a rebuilt beam from Brazil and welded some adjusters in it(the old beam was rusted thru and in very poor shape) cleaned and wire wheeled the pan head and por15'd everything while it was apart. New steering box and rag joint and new Gabriel shocks. New drums, shoes, springs, wheel cylinders, master cylinder and custom flex hoses button up the front. All the hard lines are also getting replaced as well as a new fuel line.
I am in the process of making a ebrake setup with a "custom hot rod" ebrake kit and stock cables, fun stuff:)
As of now the car is turned around and I'm working on the back half, it is mostly stripped then wire wheel time before the back half gets por15'd:)
A get the car running became a full rebuild real quick but I wanted the car to be safe for my family and didn't want it to cause them further issues and it's also been fun this is my first time with a dune buggy. And of course everyone loves pictures and plenty are here. Thanks for joining along for the ride!
Sent from my SM-N975U using Tapatalk
