TDI starter for swing axle adapter ?
panel
Post by panel »
Does anyone know if the adapters out there for sale will work on a swing axle ? They all seem to be for IRS transmissions.Looking to run the SR0408X/0409X starter. Or the 17305.
Re: TDI starter for swing axle adapter ?
Should be same starter as long as the flywheel is 12v.
Steve Arndt
Post by Steve Arndt »
westy ventures sells an adapter that works for the 002 bell housing. That will work with your swing axle trans.
Steve Arndt wrote: ↑Wed Jul 06, 2022 9:50 am westy ventures sells an adapter that works for the 002 bell housing. That will work with your swing axle trans.
That setup uses the manual trans Jetta starter (more common)
