New IDF Throttle Bodies
Paul H
Post by Paul H »
Hey
Thought I better put up a pic of the new throttle bodies
36mm bore with fully machined taper up to 48mm
Inside mount injectors with stainless steel fuel rails
Integral air temp sensor
1/8th vac port feeding from both sides
Will accept most IDF hardware
Real parts=Real Performance-Get Real
Opinion is the medium between knowledge and ignorance (Plato).
V8Nate
Re: New IDF Throttle Bodies
Post by V8Nate »
They look nice what's the cost for a pair and do they come with injectors?
Paul H
Post by Paul H »
I can supply them with injectors I suggest the Pico style which are compact and have a better spray pattern. They are $495 per pair at the moment
due to favourable exchange rate
Paul H
Post by Paul H »
I've had questions about fan housing clearance and the answer is there is plenty of clearance with a 30hp fan hosing using
tall straight or offset manifolds but sorry they won't fit with a standard fanhousing
Kafer_Mike
Post by Kafer_Mike »
Look great, Paul. Email sent. :wink:
