Project car compression ratio recommendations?
E4ODnut
Post by E4ODnut »
Hi all,
I'd appreciate some recommendations for compression ratio on our project car.
Vehicle specs:
1953 oval window street Baja
Swing axle transmission
Bus reduction boxes.
Final drive at the rear axle: 5.1:1
Rear tire dia: 33"
Engine specs:
Dual port 1641
1.1:1 rockers
Stock crank and rods
Mild port heads (53 CC with step)
Headers
Premium gasoline (91 octane)
Cam specs: BugPack 4061-10 (actual measurement @.050" lobe lift)
IO: 14 degrees BTDC
IC: 40 degrees ABDC
EC: 48 degrees BBDC
EC: 7 degrees ATDC
Int Dur: 234 degrees
Exh Dur: 235 degrees
Int C/L: 103 degrees
Exh C/L: 113 degrees
LSA: 108 cam degrees
Built in Advance : 5 degrees
Overlap: 21 degrees
Int lobe lift: .338"
Exh lobe lift: .338"
The engine will be initially checked out on a test stand with a 34 PICT-3 carburetor and assuming it runs reasonably well it will be converted to Megasquirt EFI with Mexican EFI hardware, waste spark ignition and crank trigger input.
Robert
2001 Dodge 2500, 4x4, extended cab, long box, 8.0L V10, NV4500 5 spd manual, Custom EFI
