Gerneral question on newer engines using 0w oil.
Posted: Mon Nov 27, 2023 5:24 pm
Hello.
I assumed that newer engines were tighter fitting and that's how they could tolerate thinner oils.
Like early gun manufacturing and having everything fit sloppy because the machining was low quality.
What are the facts on this subject? I did a web search and crank clearance is supposedly based on journal height of .001 per so many inches.
If this is true, how is it a newer engine can tolerate a thin oil where as a outdated design cannot? The last generation of U.S v8s can hit 200.000 miles and sometimes 250,000 with just the timing chains redone. Makes it hardly worth rebuilding a classic GM or Ford V8 if you are going to drive it a lot.
Thanks for your expertise and happy holidays to all!
