https://www.shoptalkforums.com/viewtopic.php?t=152962
In my search for a relatively simple solution to EFI a carburated stock type 4 engine, I thought this community might enjoy it when I kept a diary of the progress. And its always fun to share, so here we go! )even if updates might take a while sometimes)
Just to be clear up front: I sell nothing and just use what I see best fit for the job or whats easiest for me to get hold of. Mind you I am located in Europe.
That said, Paul from vwspeedshop.co.uk helped me get going in selling me his prototype set-up for a type 4 EFI conversion. Should be on its way as we speak
The idea is to firstly get a baseline (dyno) from a stock engine in original carburated form, then convert it and dyno it again.
For now there is some work to be done to the engine before it can be run as is.
Its an 412 'N' (set-up for Normal or regular gasoline) engine. Engine code AT. In Europe this meant a 1800 unit with 75 hp as stock and two Solex 36-40 PDSIT carbs with 29mm chokes.
A slight downside to these engines is the 210mm clutch unit as 210mm is an oddball size and the original VW412 spline is smaller then all other regular type 1 or type 2 (bus) engines and transmissions...
But, low and behold, a german buddy knew that VW Golf (Rabbit) engine had the same spline as type 1 and 2 and they were also 210mm!
Funny thing is: those disks are very cheap as a bonus!
So, here is the engine in question with its new clutch disk in place:
The engine will ride in my buggy, where the stock type 4 cooling will not be a issue
