9 tooth main shaft into early gear carrier
Posted: Fri Apr 12, 2024 2:30 pm
Hi all
Im looking to install a 9 tooth main shaft into an early(‘69) gear carrier..
I have read some conflicting info about the bearing that is needed..
Is it the carrier size or the shaft size that is different between the housing/shaft bearing?
Can I run the later bearing that come on the shaft in the earlier carrier?
The simple answer would be to use the later gear carrier, but unfortunately it is damaged beyond repair, and quite hard to come by down under.
Thanks
JB
Thanks
JB
