Does the amount of bearing crush affect the oil clearance at the bearing? Example - will an increase in main bearing crush (via line boring adjustment ) decrease oil clearance at the crank journal?
Thanks in advance.
Bearings crush and oil clearance
Re: Bearings crush and oil clearance
It would have to to some extent, but I have always just taken the case and bearings to the best VW familiar machine shop I can find and said " take my money", checking the results afterwards... Not a bad idea to give them the crank to polish/grind to suit at same time, all the rotating stuff if not already balanced. The results have always been good for me, YMMV.
Mostly replying to subscribe in case one of our gurus shows up with good detailed crush spec info.
