Inner axle gear play?
3wdub
Rear wheels off the the ground, blocks underneath the shock posts. Is there to be any play at the inner axle gears? I am getting noise while turning tight corners. When I shut the engine off it makes a grinding noise. Thanks
3wdub
Re: Inner axle gear play?
It is a vw trike, which has been sitting in a garage since 1985, what the reg.tags tell me. Lots of seals need to be replaced. Engine mounts?
3wdub
Have about 2,000 miles on it since up and running. A few 200 mile treks with it. Recent trans noise now.
3wdub
Solved through prayer. Was lead to the doghouse fan 36mm loose nut, making all the racket. Thank God, no teardown!
