Another first rebuild thread...
jalabert
Post by jalabert »
Hello anyone and everyone,
Thought I would start a thread for my pending first rebuild. I have a '73 westy which I've brought to NZ from the UK, been with me for 23 years. The egine which has just let go was installed in France in 1986 in a place called Colmar by a VW dealership called Dittel - they're still there, still deal VWs. It's got 95k miles on the clock, I've done stuff like oil coolers and pushrod seals, but I've never had cause to split the block.
A couple of weeks ago it let go rather spectacularly - huge clouds of smoke behind, some coming up through the heater vents. My heat exchangers may also be in the firing line for a bit of work. Managed to get her switched off pretty quickly. Initial investigation revealed a very oily #2 cylinder and not much oil left in the sump. A bullet dodged, I think.
I've wrestled the engine out of the bus and begun to tear it down. Initial findings are that a valve guide cracked and danced the fandango on top of #2 cylinder before embedding itself in the head.
ImageUntitled by Simon Bishop, on Flickr
I can at least confirm the engine that was fitted in '86 was a 1700 with Q heads.
I'm not 100% that the guide failed there and then. There's no scoring in the cylinder barrel, as far as I can see it could have been running like that for ages. I am presuming that head and piston are toast.
The plan is to build something that's as close to stock as I can get without it being a massive pain in the arse, and to re-use as much of the engine as I can - I've read Clatter's thread a bunch of times, what a resource. Thanks! As far as fuelling and exhaust goes, I quite like the lack of volume of the stock exhaust, and I've been running ICTs for years, which are great if tired. It will be getting a set of Way Out Westies ICTs.
I've found someone in NZ who can regrind the cam and lifters. I've been religious with oil changes, and when I've had the engine out in the past I've been careful to validate end play is in spec, so hopeful case and crank won't need too much work. We shall see...
First question...of the P&Cs that are on the market now, the 1700 offering's all seem to be flat top. There's some dished 1800s out there (and a few sets of COFAP rather than AA). Better option for a bus, yes?
I'm looking for a Q core head to match the (hopefully) good one that's coming off the 1&3 side...
Thanks for attention, reality checks, etc!
1700 '73 Westy, west side of NZ...
jalabert
Re: Another first rebuild thread...
Post by jalabert »
The other side looks pretty good, to my eye. Weird light area on the side of one piston, not sure what that's about. I'm guessing it matches up with the small area on the head where there's been some kind of a leak.
Also, that tin that fastens to the underside of the head...special place in hell for the person who put those screws in. What a shitfight.
I think I've found a good candidate core head. Thinking I will push the boat out and send them off to Ahnendorp, heard good things about their work from friends in the UK.
Arnoud
Post by Arnoud »
Hi!
Why go all the way to Germany when there are aircooled VW-rebuilders in the UK?Stateside Tuning comes to mind.He's been doing Type4's for a very long time.
Good luck!
jalabert
Post by jalabert »
I'm not in the UK anymore, I'm in New Zealand. Not really any aircooled specialist machine shops I can find here, I'm sure there's a few gems hidden away - there are some very good machinists for sure - but finding someone who specialises in aircooled heads has proven beyond my detective powers.
Signature updated!
Arnoud
Post by Arnoud »
Aahh Kiwicountry-
The Metric Nut in NZ comes to mind and what about Wayne Penrose in Australia?When shipping fees doesn't bother you then GetBackOnTrack https://www.gbot.dk/ in Denmark,Kummetat(https://www.kummetat-tuning.de/ ask for Oliver,he speaks English) or Udo Becker http://www.udobeckertuning.de/ could help you.
Cheers,Arnoud
jalabert
Post by jalabert »
Thanks Arnoud, few I haven't heard of there!
wreck
Post by wreck »
I would consider fitting 2 brand new heads . VW heritage in the UK have always been the best for price for me in Australia . Upgrade to a new 96mm bore kit to suit the 66mm stroke .
https://www.heritagepartscentre.com/au/ ... plete.html
jalabert
Post by jalabert »
Cheers, I am definitely considering the 96mm kit. I got to thinking about all the things I've wanted to do to my bus over the years, and a few of them could use a few more horsepower - I'd quite like to fit rear discs, given how much fun pissing about with substandard drum bits isn't, and that means 15 inch rims, and I've always liked that Dutch guy's bus that went down to Cape Town and to Beijing with one of Jakes motors in it.
Still in tear down mode. Having fun with my back so garage sessions are limied to half an hour at a time between visits to the yoga mat.
P's and C's all off - the pins took a bit of persuading. It's a bit of a sorry mess inside, looks like the oil turned to chocolate when it let go...
jalabert
Post by jalabert »
Progress has been slow, thanks to life and a run of good waves, but tangible. Case is apart and I've started the marathon of trying to clean enough crap off not to hang my head in shame when I take the thing to get tanked and checked out by the machine shop. Couple that I'm wondering about...
Why is this cam shell (on the left) discoloured? There's nothing obvious I can see on the camshaft bearing surface to indicate anything was amiss...
The other crank bearing surfaces look pretty even, but the back one has these streaks on it - any tell-tales there?
99.9% sure this cam is ungrindable. Only saw this wear on one lobe, wondering if could be tied to a maintenance snafu on my part, or whether it's just the universe.
Diving into the world of cam choices has been the reading exercise of the month. I am leaning towards a camper special cam kit from ln engineering - for nothing else if not for having everything matched and of as good quality as I can get. As far as capacity I'm leaning towards going 1.8 - I have a line on a set of 1.8 NOS KS P&Cs. If those don't eventuate getting anything dished in a capacity other than 1.8 seems pretty impossible. Does seem from my reading that for a bus engine, a dished piston / lower compression ratio is definitely the way to go. LN call for a compression ratio of 7.8:1 for the CS cam, and that seems like it should be (ha!) reasonably straightforward with those P&Cs.
Also toying with the idea of the full CS kit, but it's a little bit of a painful stretch financially right now...
Thanks for reading and any idiot checks in advance...
Bruce.m
Post by Bruce.m »
What do the main bearing shells look like? Much scuffing & wear or not?
The end cam bearing takes the thrust force from the angled cam gear. It’s doesn’t look beat up though.
Thankfully the case boss that the oil pick up hangs from is undamaged. Over torque on the sump plate destroys that.
You could look out for a used 2.0 crank and rod set. Then you could get 2.0 94mm pistons which are available dished if you so desire
jalabert
Post by jalabert »
Sorry, it's been a minute. Life and the never-ending saga of scraping poop off this crankcase have got in the way. Also making a bit of progress rehabilitating some of the tinware, because painting stuff always feels good.
Slowly sneaking up on the first goal of being able to put the crankcase in the dishwasher when my wife isn't looking and getting clean away with it...now the meddling kids have gone...
I think the main bearing shells look pretty mint too. There's a bit of discolouration but it feels more varnish-y than anything else. I was stoked to see the stud for the oil screen in such good shape - I was convinced that was on the way, so for the last few years I've not really messed with the oil screen. I figured that if I was changing the oil and filter every 3000 miles anyway safer to leave the thing alone without reason to believe big chunks of metal were floating around in there.
Took the plunge on a CS kit from LN engineering. Currently trying to educate myself on the deck height / compression ratio bit and what the component choices from here might look like, etc. I'm sure there'll be a bunch of stupid questions in my future.
Thanks for any and all guidance, it really is appreciated.
K70
Post by K70 »
Perhaps expensive but in the long run a wise choice.
I found (and others) stateside a funny bugger to deal with.
New heads are AMC and all innards are junk.
As not heard anything negative about that CS kit , presume then happy people don't complain.
If you find any genuine vw NOS stuff use it!
The 412LS was a good spec for a few years in the UK.
If you can get 97-99 unleaded I would copy that spec including compression ratio.
LN are gearing that kit for worst case scenario for cheapo USA fuel.
Drive a friends bus with drla or idf duals and a 4-1 performance exhaust you will be converted. No more playing the pedals like a crazy church organist! Save left knee wear!
jalabert
Post by jalabert »
Oops, I didn't put that very well - I've currently got the CS cam kit on the way, not the whole thing. Getting the rest of it is definitely an option but, er, business is going to have to pick up for me to be able to spring for that.
The (currently envisioned) budget (ha!) option is the AA 96x66 mm P&Cs and getting the original 1700 heads into order. I think I've found a place in NZ that can do seats, guides etc, and perhaps a little polishing etc along the way. If I take the combustion chamber volume taken out a few cc I think it can be built to have a CR somewhere in the 7.8-8 range with a sensible deck height...
I want to retain the stock heat exchangers, probably go with a VS muffler as they're locally available.
Making progress with the cleaning. Folowing Colin / IACs blue paper towel and gumout recommendation. Also getting through rehabbing the tinware. The powdercoat that I had done about 15 years ago has bubbled in a way I've never seen powdercoat do, I'm reluctant to subject old tin to another round of sandblasting, so I'm sanding everything down and giving everything a coat of VHT black engine enamel. The VHT header paint on the heat boxes has held up amazingly over the last 15 years, here's hoping for a repeat performance.
Pic of crap powder coat:
jalabert
Post by jalabert »
Took a break from painting tinware and cleaning the sodding crankcase today - the heavens really opened and there was no way I could open the garage door without getting flooded. Used the time to get into the crank and rods.
Checked the side clearance and everything checked out at 0.3mm on each rod. Wilson book is great, but using imperial measurements for a German engine tickles my grumpy old man gland.
Journals look to be in great shape, rod bearing surfaces are unmarked.
Next step filing the oil groove in the conrods then they can go off for rebushing. Doesn't say so in the bulletin so time for a couple of dumb questions...
1...do I file the groove both sides?
2...For rebushing, I'm presuming the machinist needs a pin from one of the new pistons in his hand when he does this..? Yay / nay, or does he need all four?!
'77 Westy
Post by '77 Westy »
Yes, to both sides for the groove. I didn’t re-bush my rods but if I did, I’d give the machinist all four pins, although they should be the same diameter of course.
