36 DRLA Velocity stacks
K70
Post by K70 »
Hi all,
Is there anyone making stack for the 36mm drla or do we just buy the 40mm version?
Should I get some made up?
What height and style has worked ok for you??
There was a rumour years ago anything taller than 3 inches was costing power on type 4 engines.
What gap overhead be optimal if that is correct?
The short alloy rolled edge stacks only seem to fit in those foam style filters I don't favor.
larsje
Re: 36 DRLA Velocity stacks
Post by larsje »
I’m making myself some 3D printed stacks specifically fitted for 36 DRLA’s.
Made them fit my air filter base etc. so there is a smooth transition.
Lower right on the picture. The ones on the carb are some I custom designed, to run with foam filters.
https://www.dropbox.com/scl/fi/2p0xogj5 ... 7qbqz&dl=0
