recently bought a CSP bellcrank linkage kit to replace the POS standard linkage I got with my dual ICT kit. The kit comes with no instuctions.
I have emailed CIP, the seller, and CSP directly for instructions.
However, I just need a picture (or description) of which linkage arm goes to which carburetor and do they pull to open or push to open the throttles?
Please don't recomment the CSP web site. They have PDF files for other carbs, and the setup is NOT the same.
Need picture of dual ICT bellcrank linkage
hannaconner
- AdminSteve
- Site Admin
Re: Need picture of dual ICT bellcrank linkage
Its the same carburetor for both sides so as the instructions say one arm will point up and the other will point down and they will both push from the looks of it. As for the longer arm it says to put it on the side that passes under the generator stand.
AdminSteve
AdminSteve
S&S Aircooled Parts and Accessories
645 S State College Blvd, Unit E
Fullerton, CA 92831
www.ssaircooled.com
(714)886-7636 Phone
Fullerton, CA 92831
www.ssaircooled.com
(714)886-7636 Phone
