Valve checking springs?
Kafer_Mike
Post by Kafer_Mike »
I need to set up rocker arm geometry with some CB Performance 1.4 ratio rockers and VW650 dual valve springs on an already built and running engine. I don't want to do it with the full spring pressure on the cam and lifters. Anyone know what valve checking springs fit a VW 044 head? The ones Brian at Type E sells are out of stock. I was looking at the common ones (4758-2), but saw feedback they won’t fit over the 044 valve guide boss.
"Build 'em fast...or let 'em sit"
V8Nate
Re: Valve checking springs?
Post by V8Nate »
I used some springs from the shocks of a r/c truck when I was doing my rockers and it worked out sweet
Kafer_Mike
Thanks, Nate. What scale - 1/8 or 1/10?
BFB
Post by BFB »
Brian has some back in stock, better grab ‘em while theres still some available
Kafer_Mike
BFB wrote: Fri Jan 09, 2026 6:44 pm Brian has some back in stock, better grab ‘em while theres still some available
Ordered a set. And they arrived last week. :wink:
