Weird Flywheel
Tom Perso
Weird Flywheel
Post by Tom Perso »
Hello All...
I have two 1.7L motors. The one I have torn down has a dipstick tube like a T1, not the long type that was put in vans. Also, the flywheel does not have the needle bearing in it, the bearing in the crank. Is this a Porsche motor, or what is it? I know that an easy trick to put T4's in T1 trannys is use the 210mm bus flywheel with a different needle bearing in it. But this one is in the crank... What gives???
Thanks!
Tom Perso
Joseph
Weird Flywheel
Post by Joseph »
If the pilot shaft bearing is in the
crankshaft it means the crank started its
life as a stick shift Type 4 Bus crank or
a stick shift 411 crank. If the case has a
dip stick on top (not quite like a Type 1)
its not a Type 4 Bus case. Note that after
30 years, a lot of changes can be made by
each owner. Normally, the 914 has the pilot
shaft beariing in the flywheel so that
engine was not hooked to a 914 trans.
Installing the 210 or 215 flywheel requires
machining the flywheel, installing the pilot
shaft bearing in the flywheel and using a late style TO bearing on the Type 1 trans.
Joe
Oregon Performance Products http://www.spiretech.com/~opshroud
