valves wont adjust
veedawg
valves wont adjust
Post by veedawg »
the valves on #3 & #4 wont adjust the screws are turned all the way out. i know im not doing them in the wrong order ive done this plenty and have never had this problem. the dist. is not in backwards either i am completely baffled. i just bought this motr so i dont know much else thank you
Thorkhild
valves wont adjust
Post by Thorkhild »
Image Doesn't sound Good! Maybe try taking off the rocker arm and re torque it down. Inspect the pushrods and make sure they are all ok. I had teh same probs on a new engine. I had to put shims under the rocker arm blocks to adjust 'em.
Thorkhild
1968 VW Blue Fastback
My Car Page
veedawg
valves wont adjust
Post by veedawg »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Thorkhild:
<B> Image Doesn't sound Good! Maybe try taking off the rocker arm and re torque it down. Inspect the pushrods and make sure they are all ok. I had teh same probs on a new engine. I had to put shims under the rocker arm blocks to adjust 'em.
</B><HR></BLOCKQUOTE> ive triied a completely different set of rockers. what are shims how do i use them and how do i determine the right size? can i just use washers until i can adjust? thanks for your help
