What does it take to put H2O in a bug?
nicanor
Post by nicanor »
I started considering puttin a 911 engine to replace my stock 1600cc engine, but the price it too high for the engine itself. I've read some posts here that total conversions can cost around $2k, more or less, so now maybe going down the road of a GTI engine.
What does it take to put one of these in a stcok bug? Obviously the engine, tranny adapter plate, clutch and radiator. Was there anything I should look for besides body clearance? Any info would help.
gatorvws
Post by gatorvws »
What does it take to put H2O in a bug? A water hose in the window??? Sorry the Texas heat has refried the brain. Seriously check out "Superman's" (forum moderater) web site he has a GTI in his super. Hopefully he will chime in. The only problem I see is you will have to modify your deck lid due to length of the motor.
http://www.geocities.com/superman1303/mysupertn.html
Later
Alan
spider 49
Post by spider 49 »
How do you get to supermans website, I seem to be daft. thx
spider 49
Post by spider 49 »
Never mind, as soon as I posted my last message I seen the address in your post. Dang me.
jmillheiser
Post by jmillheiser »
you could also convert to the VW waterboxer which from what i hear is a fairly common conversion in europe. then you have a watercooled motor that will fit in an aircooled VW engine compartment.
2k for a 911 conversion sounds a lot low.
911 motors usually sell for a lot more than that
