I was wondering would some type a fan and tin set up, something like the Porshe style cooling fans and set up some how made or adapted to a Rotary engine help in keeping the engine cool along with a front mounted Raiator....
BoricuaVolky.....
Would this help with cooling????
oldbugs
Hey BoricuaVolky you ever go to tower shops in Davie?
BoricuaVolky
OOOOOHHHH YA...
I try to go every Friday, I go just to see who brings thier bugs but usually only see one or two,
BoricuaVolky
BoricuaVolky
Jim Molloy
The best thing you can do to help cool a
Rotary engine is to use the early style(79-81)oil cooler or a larger aftermarket style.
Also a electric fan to blow on the oil cooler.Oil coolers were always used on Rotary engines from the factory.With a good
radiator and oil cooler you should not have
any cooling problems.
72 SuperVert(Rotary engine conversion in process)
