Full auto trans?
crw432
Full auto trans?
Post by crw432 »
I know, I know, Why an auto!!! But I have my reasons, how can I get a auto in a 914?
Bleyseng
Full auto trans?
Post by Bleyseng »
Sporto been done by the factory if that is "auto" enough for you.
Geoff
76 914 2.1L
www.914Club.com member
Dave_Darling
Full auto trans?
Post by Dave_Darling »
How can you?
Lots of fabrication and custom-building. All of the ones that I have ever heard of have been done in the course of an engine swap as well. The builder simply swapped in a whole drivetrain complete.
Not for the faint of heart. No kits available that I have ever heard of.
--DD
Mueller
Full auto trans?
Post by Mueller »
Like Dave said...no kit's....however, the Audi transaxles could be adapted to work with enough time and money Image
The "easiest" I think would be to use an Audi or Passat engine/tranny combo and swap the entire drivetrain in....
Loan Dog
Full auto trans?
Post by Loan Dog »
Buy a Buick
metropoj
Full auto trans?
Post by metropoj »
Try a VW Type III fully automatic. They're borg warner designed, come from a VW and will handle stock 250 HP no prob. See the Type III links to see what's involved with at least getting a Type 4 motor into a Type III. Some of those ideas will transform over. BUT tranny is reverse of 914, as is the Audi ones for sure. Good luck .....
Full auto trans?
Post by Marc »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by metropoj:
Try a VW Type III fully automatic... <HR></BLOCKQUOTE>
In a mid-engine car?
Dave_Darling
Full auto trans?
Actually, the Audi trannies spin the right way around. The earlier (pre TT) FWD Audis all had longitudinally-mounted engines, so the engine sat in front of the transaxle. Which is the same way it sits in the 914.
Most FWD cars today have transverse-mounted engines, so the engine sits off to the side of the transaxle. Not so easy to adapt.
I didn't realize there was a full auto-tranny version of the Type III. Was there one of the Type IV? You'd have to do some work to see what was involved in flipping the ring and pinion gears around to make the transmission turn the other way. But it might be less fabrication to get it to work than the other possibilities... Maybe...
--DD
Full auto trans?
Post by Marc »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Dave_Darling:
<B> You'd have to do some work to see what was involved in flipping the ring and pinion gears around to make the transmission turn the other way...
</B><HR></BLOCKQUOTE>
Can't be done, the Audi idea is better.
Bleyseng
Full auto trans?
Post by Bleyseng »
Try a 411/412 auto trans as there should be a ton of those around. Most 411/412 cars came to the US with auto's from the factory. The stick cars went to Europe.
Geoff
76 914 2.1L
Dave_Darling
Full auto trans?
Marc, is it physically impossible to flip the R&P in the Type III or 411/412 auto trans, or just a major pain? I know people who have flipped 930 trannies, where you have to do a goodly amount of machining to make room for the new ring gear location.
Is there simply not enough metal around to fit the ring gear on the other side? Or is this one of the "well yeah, it's possible, but it's a pain enough that any other option is better"?
--DD
bernbomb914
Full auto trans?
Post by bernbomb914 »
Would a Honda engine work as it turns the other way?
Bernie
[This message has been edited by bernbomb914 (edited 03-15-2003).]
raygreenwood
Full auto trans?
Post by raygreenwood »
The type III and the type 4 auto were the exact same part. The only differences were the final drive ratios (there were a couple in both cars) the bell housing, the cv hubs..which are interchangable depending on wether they are early or late with through bolts into the differeential...or not. The diff comes off with 4 bolts and is a totally separate unit from the auto box section. So if you have a good diff and a bad auto box...its a 10 minute swap with a new pair of seals. Do not throw differentials from these away. they are bulletproof...and the parts are around to rebuid them. I have never tried it...but since the bolt pattern that holds the diff and bell housing is symettrcical...you may simply be able to flip it over. Ray
bernbomb914
411 auto trans
Ray where would I find a 411 auto trans in good condition with the highest ratio. How much should I pay? Is there somewhere in SO Cal that one could go
Bernie
raygreenwood
They are generally not too hard to find from the type 3. There are several ways to look at this. The type 3 and 4 auto boxes were identical...except for the bell housing, final drive ratio and a few adjustments. If you are putting this in a type 4....2 or 4 door sedan, and the auto matic is there...just bad...use one from a type 3 and swap the bell housing (5 minutes).
The type 3 auto had a couple of ratios for final drive as well, but the auto in the fastback had a 3.67:1 final drive.
I don't know if the bell housing from an auto bus will unbolt. If it does its should fit on a type 3 or 4. I would find a type 3 auto from a fastback and ask some of the type 4/ 411/412 people if they have a spare bell housing to sell. If they have more than one tranny at all, they could spare a bell housing. Ray
