early bus dropped spindles for sale!
rizzag11
Post by rizzag11 »
here is the link to my ad. http://www.thesamba.com/vw/classifieds/ ... 2107024951
thanks for looking.
Pillow
Post by Pillow »
Killer bus!
Adrian Pillow
'66 VW Westfalia - "Biscuit"
'67 VW Deluxe Westfakia - "Dino" - FS
'79 Porsche 911 SC - "Cochese"
rizzag11
Post by rizzag11 »
thanks! alot of hours!
Pillow
Post by Pillow »
You got mail! Granted not necessarily a bus spindle.
Adrian Pillow
rizzag11
Post by rizzag11 »
shameless bump
WAVEPIMP
Post by WAVEPIMP »
Frank -- I hope you didn't take that the wrong way? Your drop spinndles look excellent and I'm sure they are hard to make and take time. And I know time isn't cheap. I'm the guy from Houston that talked to you on the phone once about ur beams and what size tires will fit and not rub in the back of a bus( you probobly don't remember me) but I really like what you are going. Just so you know That I didn't mean anything negative on my last post.
Laters James
rizzag11
Post by rizzag11 »
no disrespect frank, but obviously you have never built a set of as you call them "reverse" spindles if you think that parts get swapped from side to side. if you have you would know that all the parts stay on their respective sides. also there is some machine work required on the backsides of the spindles. and i fully weld the gusset and not just a couple tack welds on the gussets. you make it sound like it is a fifteen minute process.
p.s. i always recomended you in the past for beams and disk braks spindles
WAVEPIMP
Post by WAVEPIMP »
Riz--- you need to make some for baywindow buses!!! Seems that frank is the only I have seen so far doing this. They are just out of my budget right now.
Laters James
rizzag11
Post by rizzag11 »
what are you talking about? i know franks stuff is real nice, im not the one that trivialized another persons work??? and was wrong when i was doing it. maybe you need to talk to your husband and not me.
rizzag11
Post by rizzag11 »
my appologies franks wife, i now see that you said you were chewing him out too! but i must say all i was doing is defending myself and my product when it was demeaned by another.
rizzag11
Post by rizzag11 »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Franklin's VW Werks:
<B>Rizzag has asked for an apology from Franklin for a so called diss on his product. However, Franklin has not dissed Rizzag's product, Franklin was just trying to show why his product was more expensive. That is all.
If that is not how Rizzag is making his spindles then there should be no problem, noone should be getting upset at all. That is how Franklin understood the reverse spindles to be made, although Franklin is not into doing them.</B><HR></BLOCKQUOTE>
there wasnt a problem, i didn't start this, i was minding my own buisness, then i defend myself and you come blabbin in telling me to stop being a child, acting like a little child.
"my stuff is better than your stuff", "no, my stuff is better than your stuff".
Knock it off, grow up, and act like adults
sounds like you need to take a little of your own advice.
also that sure didnt sound like an apology and was very condescending in my opinion
for the record i tried to clear this up and YOU franklins wife keep dragging this out.
this is a simple misunderstanding that has been blown way out of proportion which has not been helped (although i think you think you are making the situation better) by you, you have only made it worse.
im done with this, for the record, i think franklin does very nice work, i have no problem with franklin, i only wanted a little respect for the work i was doing, that doesnt seem out of the question to me?
