Head Welding
fredybear
Head Welding
Post by fredybear »
2 of my exaust studs on my eepco heads were drilled out oversized and one of them was installed crooked they will work but i dont like them that much...they could b better...what does it take to weld these up and re tap them....a mig with special wire...a tig...???? comments...
Fredy-
55 bug-
63 bug-
Head Welding
Post by Marc »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by fredybear:
<B>2 of my exaust studs on my eepco heads were drilled out oversized and one of them was installed crooked they will work but i dont like them that much...they could b better...comments...
</B><HR></BLOCKQUOTE>
Did they take them all the way out to 10x1.5 for the step-studs? (yecch, I prefer helicoils or Time-serts).
You may be able to improve them a bit without welding by using casesavers cut to length - red Loctite the insert to the head and use antiseize on the stud (you could even custom-bend a stud and nobody but you would know the threads are crooked)...
fredybear
Head Welding
Post by fredybear »
yea thier step studded...someone did it while the engine was in the car and did a crappy job...i did the same on my 1600 just drilled and tapped m while the engine was in and they came out perfect....never let anyone touch your stuff...i have a bunch of case savers... thats a good idea plus the others u metioned...also ive been doin all this research and i might upgrade even more.. so i might sell the heads....im confused....
Fredy-
55 bug-
63 bug-
