I am heavily leaning to a 1904 (74x90.5) for my bus engine and figure that if a 76mm WBX crank will work that it would be a lot cheaper and a darn good crank for the bottom end.
Apparently the #1 main bearing needs clearanced for a T4 #1 main bearing, but all the other mains are the same as a T1. T1 rod journals are already there on the 76mm crank so no problem there. The cylinder offset is perfect for a T1 as well.
Basically the WBX is a T1 that is watercooled, the case internals are very similar to the T1 and stuff.
In theory I could get a AL case from aircooled.net and have all the machine work done for the #1 bearing right off the bat. As well as opening the jug holes for 90.5As and full flowing the case.
I am still torn on the Birals from Shad with JE forged pistons. Half of me says that the 90.5s are robust enough as cast steel. Then the other half says if you go Biral just get 94s because they are so much better with heat transfer. Then again why get JE forged if you are not running high CR or any "power-adders"... Soooo many variables to think about!
Then again why bother and just build an el cheepo 1914 and keep blowing it up every 30K
Adrian Pillow
'66 VW Westfalia - "Biscuit"
'67 VW Deluxe Westfakia - "Dino"
'79 Porsche 911 SC - "Cochese"
