Fan shroud compatibility
Derek56Oval
Post by Derek56Oval »
Will an original (german)1200cc fan shroud work with a built up dual port motor? I found one without freshair holes and would like to use it for my engine build.
Bent
Post by Bent »
No.
robh
Post by robh »
There's good aftermarket fan shrouds without air duct holes in them. I cut and welded my original 1600 dual port fan shroud, but the welding warped the metal a bit, so the fan would rub slightly. I had to tweak it to fix that. Not a big deal, but it was so much easier to just buy one pre-made, that fit the oil cooler location of the dual port case. Mine's a "36hp" style fan shroud, which leaves lots of room to adjust the dual carbs.
[This message has been edited by robh (edited 07-17-2002).]
Post by MASSIVE TYPE IV »
Aftermarket shrouds suck in my opinion....no doubt
Post by Marc »
It will fit if it's from a `61/`62 non-fresh 40HP (a true 36HP shroud won't fit on a 1600 case without butchery) but it's designed for the old oil cooler setup which was borderline for stock engines and inadequate for hotrods. Even if you use a remote cooler, this kind of fan housing lacks the internal vanes that distribute the air to the LH head - with no cooler inside, they'll overcool the base of the LH cylinders and undercool everywhere else. You can do better.
robh
Post by robh »
Massive Type IV,
I wouldn't argue that aftermarket cylinder tin sucks...It always leaves huge gaps that sort of defeats its purpose in the first place. As far as the doghouse, though, if you want the "early look" on a later engine, I can't think of any better way than to go than aftermarket. I know a guy who modified an early shroud to fit a 1600 dual port, but it was major surgery and maybe not worth the effort (he thinks so...for him, welding is theraputic). Is there another way? I wouldn't be surprised if I've been missing something.
Bob Ingman
Post by Bob Ingman »
The fanshroud from a 73 Thing is a factory solution. It has no fresh air ducts (used gas heater) and is made for late DP engines.
Good luck. Bob Ingman
vdubsinjensen
Post by vdubsinjensen »
Have you seen what 73'thing fanshrouds are selling for? The last one I saw on E-bay fetched $205.00!!!!It makes me wish I would have kept a few of them. Paul www.jbbugs.com
Bob Ingman
Sold one for $75 the other day. Seemed like plenty to get for it. Good Luck. Bob Ingman
