Hello all..
Bottom of the case on the side (side of the sump)it appears to have some numbers(043.101.101).
Does anyone know what is these numbers??
Thanks in advance,
Jim
What is this??
What is this??
Just casting numbers; the only number of interest down there would be the alloy ("AS21" or "AS41")
You can tell much more about an engine from its serial number.
- Larry_sb
What is this??
Marc,
Can i found from the numbers the year of my engine??I know it's an AF.
What is this??
Ordinarily you can (unless it's a replacement case). AF never were offered in USA so I'm not certain but I'd guess it's a 1300 from the early `70s.
Peppe?
Peppe?
