Valve Guide Replacement?
Posted: Fri Oct 18, 2002 12:05 am
by sparkmaster1
You need use a coring drill bit and press them out. It's stepped so that about 3/8" of the guide is still solid to press it out with a angle head plate. Tim
Posted: Fri Oct 18, 2002 12:57 am
by rich2481
you can set the head in the sun for awhile, but then it does get hotter than hell here most days, dont know how hot you can get them up in Canada....
if not drilling is the way to go, I have used a long carriage bolt grinding the square off the inside of the head, and using a socket that clears the boss on the other side, with washer and nut
