Flywheel reduction tool is the best way. You don't need a huge ass torque wrench to tighten it back either.. and NO stress to the case.
My VW Page
Stubborn Flywheel
vicsvw
Stubborn Flywheel
Your going to replace it any way so if you don't have access to an air impact wrench you can use a chisel to unscrew it. Vic >> http://www.1800vw.bizhosting.com/crankshaft.htm
- speedy57tub
Stubborn Flywheel
When I have this problem, I try to different things. Try heating the gland nut and/or using a "buddy-bar" and pipe for leverage. The "buddy-bar" and a chubby friend or two(maybe a six-pack) works great. have one friend stand on the long block, one hold the "buddy-bar", and you, via a pipe, heavy-duty ratchet and socket, loosen the gland nut. Apply heat if needed but I think you'll be fine. Last step, is pull on the tab and drink up! BTW, the "buddy bars" can be also used to remove axle nuts too!
Thanks, speedy57tub
(Speedying around and about "Viva Las Vegas")
Thanks, speedy57tub
- 71Vdubber
Stubborn Flywheel
Ok, here's I went through to remove my gland nut:
420 ft/lb air impact gun - not a twitch.
Chisel and mallet - chopped clean through one section of the nut, still not a twitch.
18" long 1/2" thick breaker bar and 4' cheater, engine braced to floor with angle iron - Bent the angle iron, eventually broke the breaker bar and rolled the engine around on the floor!
4' cheater with a 36mm socket welded to the end, engine braced to floor with angle iron, 175lb friend standing on the engine - success!
Those things can be put on TIGHT! It was 'only' a standard gland nut too, I hate to think what the racing ones are like!
[This message has been edited by 71Vdubber (edited 11-19-2002).]
rich2481
Stubborn Flywheel
A little heat dont hurt but a buddy with a good air gun is better, I do not like the flywheel lock for torqueing and untorqueing as there is a chance to crack/break your case
- Drake
Stubborn Flywheel
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by vw_dave:
<B>
I've never heard of a flywheel reduction tool. What is it? Where could I get one?
</B><HR></BLOCKQUOTE>
A.K.A the Torque Miester. Look in a Kymco ad in a VW magazine
<B>
