vac. assist brakes and 40webbers
do I have to drill my manifolds or is there a place on the carbs I can get vaccum from. thanks
You need manifold vacuum for power brakes, there's no way to get it or anything close to it (with a sufficient size) from the carbs.
Since Webers don't need or want an equalizer pipe like dual-singles use, I'd get an extra checkvalve from the wrecking yard (also a good source for the extra hose you'll need for cheap - look at Rabbits/Dashers and the like) and tap both manifolds. Run a hose w/checkvalve from each manifold to a tee-piece connected to the main line that goes up front.
