Master cyl. reservoir
Can't afford the rare and extreme car of your dreams? Well just build one.
2165 Turbo Rail
Post by 2165 Turbo Rail »
Does anyone know what type of Reservoir can be used on the dual master cylinder like the 69 bug came with instead of having the remote mounted plastic one with lines going to the master cyl.? Someone at the Bug In in Texas told me of a reservoir that comes on a volvo that will fit right in the dual stage master cyl. if you take out the 2 hose fittings..
Thanks,
Chris
2165 Turbo Rail
FOUND IT!
incase anyone else is interested I found the reseroir
VOLVO 140, 142, 144, P1800, 164, BRAKE MASTER CYLINDER BRAND NEW ATE WITH RESERVOIR #03.2122.1905.3 VOLVO # 673766-2 OR 678921-8. off of a 1972 - 1983
murzi
That was me!
Post by murzi »
Use the volvo 240 on aftermarket MC's ---13mm nipples.
Use a rabbit res on the original MC 10mm nipples.
Murz
bittenbythebug
Post by bittenbythebug »
where can I get a resovoir like this? 8)
derail
Re: FOUND IT!
Post by derail »
Hey I'm interested in where you found the reservoir. My email address is [email protected]
Derrall
