blasting and surface rust/paint removal
ryan68bug
Anyone here have any estimates on what it costs to get a Bug shell walnut or plastic media blasted? Second question: approximate cost to blast and powder coat a floor pan? Thanks.
Guest
Guest
- deac
500 dollars for blasting and primer is an awesome deal. That would have saved me soooo much time if I could've found that around my town. If you decided to do it yourself, be very careful. The sand abrasion will cause a lot of heat on the surface of the car and may warp the metal. Plus it's murder on your compressor and you'll get sand everywhere. Just my opinion.
deac
deac
Air-Cooled Head
Beg to differ. Read the comments of Major Woody, here;webs1302s wrote:You can do it yourself for A LOT less. You can buy a sand blaster @ Harbor Freight for less than 100 bucks that will work with a low end compressor.
http://www.thesamba.com/vw/forums/paint ... g&mid=2722
55rag
If budget is your main concern I would use a combination of chemical/sandblasting. I have done this in the past with good results. It wasn't that much cheaper than paying to have the car stripped. I bought a couple gallons of automotive paint stripper plus scrappers, wire brushes, had my buddie help. That took a few weekends, then sandblasted all the detailed areas. It probably cost around $300 -$350. Just be very careful and clean the car very good and primer ASAP.
P.S. I will NEVER do this again. It took some very hard work and the results aren't as good as having it professionally done.
Guest
I blasted a 62 with the 40lb hopper from Harbor Freight. The blaster itself works ok, and if you have the time and place to do it then I recommend it. The only thing I didn't like about the blaster from Harbor Freight was that the only media that works is the fine silica sand which is deadly and makes one hell of a mess. If you are restoring a car buy a nice blaster where you can just pour the media into it instead of using a funnel. There is so much that sand blaster can be used for I think it's a great investment. If your like me and still plan to restore a few more cars then its a no brainer.
Just think of all the parts that need cleaning....pans, body, tins, rims, brake drums, front beam, seat frames, etc...
On another note, powder coating is good for durability and finish, but I'd recommend POR-15 chassis coat. You can apply it yourself, you pans will never rust again, and the stuff will never come off.
- Phil Smith
Guest
I had my whole car and most all parts sandblasted for less than $200 locally. Might have been even cheaper if I'd taken everything at one time. The place that did it is the place that does cemetery headstones, oddly enough. I asked the guy to be careful about heat and warpage and he told me not to worry. I did worry but it was for nothing because everything came back completely clean and not warped. It was a pain to get all of the sand out of everything, though.
I think the warpage thing is overblown if you go to a reputable and experienced place. And $500 sounds like a lot (maybe not, if includes primer).
john @ no dollars racing
Guest
