Headers on a Bus
turbo_tangerine
71 Bus. New 1600cc motor that will be put in it this weekend. So Cal driver. Hills galore. Not looking to race, but give it some juice up the hills and make it as efficient as possible. Old tail pipe fell off and since I'm about to put a new motor in, I figure maybe this is the time to consider headers...
turbo_tangerine
- Eaallred
There is a line across the road at the top of a freeway onramp that I drive on everyday. The header was a sugar pill, as I thought I was going quicker with it, but found that I was up to 56mph when I crossed the line wether I ran a header or a stock muffler. 64 bus, 1600DP.
Eric Allred
1963 "Street Legal" Drag Bug
MegaSquirt 3 Crank Fire EFI
- [email protected]
If you use a 1800 t-2 muffler The kit is $200.00 you will get more performance and it will be quiet and not drag on the ground like the headers everyone sells, it fits up niclly in the stock locatation. the only draw back is you will neen to flange your heater boxes and modifiy the Primary pipe. Jess
mschilling
That's an idea I was considering for my original 71 bus. CIP sells a Type3 exaust kit that uses a stock 72-74 bus (Type4) muffler and has pipes that adapt it to the Type3. Since the heads are same as a Type1 the upper pipes will bolt right up and all that's left is to adapt the heater boxes to the lowers. Then you could use their large diameter heater boxes to complete the bigger overall exaust. You get stock quiet muffler sound and fit with the size to match an 1800 Type1 (or larger) motor. Sounds good but wonder if it will fit like the original bus muffler?
- [email protected]
mschilling
Hey, thanks for the response! I've checked your website, very interesting items on it, unlike any other I've seen. Have you thought of putting together a bus exaust kit like we've discussed? I'd be interested, and I'm sure many other bus owners with raspy, rusty, ugly headers hanging out below the bumper would like it too. Also, those 4-piston calipers for the stock type1 front brakes sound neat, although the pic shows what appear to be 2-piston calipers. What car are those from? The price is very tempting at only around $100 each, and they would go very well with the rather large rear discs that we have been installing on our bugs.
Guest
