sealing up oil pump?
Posted: Thu Jul 31, 2003 7:09 pm
by wbx
What do you guys do to effectively seal a type 1 oil pump? Aside from using new sealing nuts, do you coat those thin paper gaskets with anything?
Thanks,
-Damon
Posted: Thu Jul 31, 2003 11:11 pm
by milo
I use a light coating of copper rtv.. I just put some on my fingers and rub it around the gasket... Havent had a problem yet.. If you don't use anything more often than not they leak..
Nathan
Posted: Fri Aug 01, 2003 1:06 am
by wbx
Thanks for the quick reply, Milo.
Now, not to sound totally inane and belaboring minutia, do you just thinly coat the gasket between the pump and case, or both pump/case and pump/cover?
Posted: Fri Aug 01, 2003 1:11 am
by Guest
should be two gaskets, one between the pump and case and one between the pump and cover.. I coat both..
Nathan
