bondo is it the standard
angelo
all the local autozone type places carry it...is it reccomended by you guys also...will it hold up very long. I need to fill in a few dents and eventually fill in around some sheetmetal......thanks......
- DougRuss
If you can, try and stay away from "Bondo" brand products !!
Go to your local parts store or order on the Internet , "Evercoat" brand fillers.
Here's a good one to work with :
http://www.eastwoodco.com/itemdy01.asp? ... 61&I1.y=42
Also try "Rage" and Rage Gold" fillers by the same company !
john @ no dollars racing
angelo
I forgot to mention that when i was grinding everything down to bare metal i hit alot of areas that already had filler of some sort....especially around the headlights and a few other ares.....the filler on your link said metal to metal which is perfect for my dents....but how do i approach existing filler....while grinding off the paint i put all kinds of gouges and what not...especially around those damn headlights....
- roachghia70
por 15 paint can be your best friend if there's rust involved. i agree, evercoat is the way to go with filler. you don't have to grind away all the old filler, but if there are any cracks in it or any adhesion problems, you should grind it away and re-apply the new filler. don't worry about your grind marks, you should have a fairly rough surface in order to get the filler to stick.
ck85abc
angelo
