Grafting a sunroof
David Miskov
Grafting a sunroof
Can anyone give me a rough idea of how much it would cost to have a sunroof cut out off one car a grafted onto another? Thanks.
amoto
Air-Cooled Head
Air-Cooled Head
I used the instructions in my link, above.
Just take your time and measure, measure, test fit, measure & repeat. I truly spent more time on measurments and alignment than on welding. I cut the opening small intentionally, then spent a lot of time trimming. I grafted mine about 3 inches further back than stock, still turned out perfectly.
TIP: If you cut out the donor clip, leave as much surround as you can, then trim. And cut your opening slightly smaller. Pleanty easy to remove more metal,
but if you remove too much,,,,
Better safe than sorry.
