engine tin ?
eviloval57
engine tin ?
Post by eviloval57 »
Hi I got a 56 bug and the sheet metal in the engine bay has been cut out its the parts that are next and behind the engine the part the seal goes in.If I put a 1600dp with engine tin in will it overheat.Thanks
Glenn
Post by Glenn »
I'd replace it.
eviloval57
I dont want to fix it now but drive it till a latter date plus I have to get the parts used and I want drive it now.
racelook
Post by racelook »
Reclape it...
THere can be a change of overheating... I woudend risk it.
Greetings Wiebrand
Rescue912
Post by Rescue912 »
It will overheat. If you don't have the time or cash to replace it at least scab something together to seal it up. Make a cardboard template, transfer to some sheet metal and start cutting.
I agree that replacing it is still the best option though. You can get rear aprons pretty reasonably (well, somtimes anywho) and some aftermarket removable ones that are pretty spiffy for a bit more.
