Head gaskets?!!!
- 69SQBCK
Head gaskets?!!!
I just removed the #3&4 head off of my type 3 1776 and wanted to let everyone know that the copperhead gaskets from CB Performance that I put in there the last time worked great. I would definately recommend these to anyone looking for a better cylinder to head seal. I used a set of the .060 gaskets and did not notice any drop in performance due to compression. Thought I would share this info in case anyone was giving it some thought.
www.1800vw.com
No Difference
If you changed the deck height .060 and it made no difference then you got problems that should be checked out. Vic
