Oil additives???? Good or bad????
- jguenther
Trying to delay having to rebuild my 1600DP. I know that it will have to be done in the near future but funds are tight. My engine gives a puff of smoke when I start it and when I really get on it. Will some type of oil additive help with this problem? If so, what kind would be the best? I see all kind of stuff advertised to recondition seals and such but I didn't know if it would be a good application for the air-cooled because of the smaller volume of oil in the engine. Thanks in advance!!!
John Guenther
John Guenther
- Mach1VW
- Mark the canuck
- bedlamite
In many cases additives can do more harm than good. Before you use any, take a look here:
http://www.google.com/search?hl=en&ie=U ... es&spell=1
- Mark the canuck
Eric Allred
- jguenther
Something else to add. I bought the car (72 Ghia) about 2 months ago from a guy here in Iowa and immediately took it to the local VW shop for an oil change. When I checked the level a week later after driving it a lot, it was about 1/4 - 1/2" above the top fill line (it has stayed that level since). I didn't think that would make too much of a difference since it was leaking just a tiny bit. About 2 weeks ago, I took it back to the mechanic and he said that it was most likely fuel that was mixing with the oil. This would make sense if it was too rich right?!?!? Also, the PO bought the car from a guy in Colorado but I don't know if he did anything to the engine to compensate for the altitude change. Does all of this make sense why it would be running rich? Thanks!
John G.
John G.
- ANT
If you're running too rich it IS possible for fuel to get into the oil.....you do NOT want this. Fuel will dillute the oil and you'll get major major wear very quickly. Your rings will get shredded and the bearings will disappear.
As for that 009 dizzy. Remove it ASAP, place it on the ground, and gently strike it with a 10 lb sledgehammer until it's unrecognizable. What I find on my toilet paper is better than those dizzys. Run one with vacuum advance and feel the power under your right foot and the swell in your wallet (from not having to spend as much money on gas).
-ANT
-ANT
Guest
Wow, Another quite pleasant post. Two thumbs up.ANT wrote:If you're running too rich it IS possible for fuel to get into the oil.....you do NOT want this. Fuel will dillute the oil and you'll get major major wear very quickly. Your rings will get shredded and the bearings will disappear.
-ANT
