Good thing I always check to make sure my buggy is out of gear. I flipped on the "night" switch (trucker term for battery isolator), turned the ignition key to on, then walked around back to the engine. There, I worked the throttle on the carb to set the choke on, reached for remote ignition (on/off) and the instant I hit it, the engine roared to life. And it had been a week since I last fired it.
Didn't get near the starter button. This was simply a cylinder on the power stroke and one plug firing as the CDI discharged. One for the memory file...
CDI = easier starting... maybe too easy!
- Max Welton
