How do you use them? I cant figure if you hold it over the dent and wack it, or do you hold it over the dent and hammer the backside for the dent?
DUH,
Ron
Question about shot bags
- John Kelly
Hi Ron,
A shotbag is used in conjunction with a hammer to stretch metal...not something you need in standard body work. It absorbs the blow of the hammer or mallet. You hit metal a lot ending up with a lumpy piece that needs smoothing. A number of ways to do that...english wheel, hammer and dolly, planishing hammer, modified vice grips... Here is an article with a bit about dent repair buried in all of the welding talk:
http://www.type2.com/library/body/wlsh.htm
John www.ghiaspecialties.com
