Temporary rust control
Posted: Tue Jan 13, 2004 4:10 pm
Hi everybody,
I have just acquired a 72 squareback that had an engine fire that melted the paint down to the bare metal on the rear apron and the trunk floor and melted the top layer on the sidevents, exposing the primer layer. The PO used water to put out the fire, so there is some surface rust starting on the trunk floor and rear apron.
Naturally I would like to nip this in the bud before it gets any worse. What would you recommend as an easy way to stop or greatly retard the surface rust from getting any worse? I would like to avoid dismantling the car too much for now as I would like to get the engine in order and running (a whole other mess)before I even think about doing bodywork. When the time comes, I want to completely disassemble it and have it painted, but that won't be for a while and I want to make sure that the body will be reasonably protected for the next year or so.
BTW I am located in San Diego.
Thanks in advance,
Matt
Thanks in advance,
Matt
