help alfa boxer install
sparkyshep
hi i am looking for a adapter plate to fit my 16v 1.7 alfa boxer engine onto my bug gearbox has anyone know of a supplier any help welcome thanks
sparkyshep
re engine
thanks rob for the tip this engine is excellent so much potential i have striped the engine down the porting in the heads is excellent my mate is getting worryed he has a 2.2 air cooled bug i recon a good thrashing is going to be the order of the day
TIMBERWOLF
Sparky, check out www.ricola.co.uk this guy did an alfa into bug for his speedster good info on the site, then he went turbo scooby power.....
Let us know how you get on with GB engineering, I'm thinking of going to them for a volvo to vw adapter, but I expect it'll all be custom, I don't think they do one of the shelf.
sparkyshep
alfa boxer conversion
have ordered my engine adapter from gb engineering guy seemed fairly helpful cost was £248 ukp if anyone is interested thanks sparkyshep
sparkyshep
spindle length
as soon as it turns up i will measure the length is yours the 16valve engine or 8 valve thanks steve
sparkyshep
adapter plate
the plate turned up after a 4 week wait it is good and will only need a little grinding to clear my crank sensor but this is not a error on gb engineerings as i did not request the cut out. the input shaft is 31.2cm long thanks steve
- Richard Olafsson
sparkyshep
adapting adapter plate
as i am using the 16valve engine the starter comes with a spacer plate as standard and the flywheel has got a pickup ring bolted to the front of the flywheel so i have been lucky and have only had to grind for the cranksensor no clearance prodlems so far thanks steve
sparkyshep
re fuel injection
I was going to retain the fuel injection as it seem quite a good setup with the throttle bodys 40mm in size as the wiring is no problem as i am a auto sparky I dont think there are manifolds to fit this engine to run carbs as the intake port is a different shape than a 8 valve.Why ,what did you have in mind kafercup1???
sparkyshep
re carbs
hi kafer cup the guy i bought the engine of races alfa 33,s his car runs 180bhp on fuelinjection but changes the cams but there a bit pricy at £800 he recons that a early 1200 alfasud ti engine manifolds may do the job. i am running the fuelinjection as you can get a chip for the injection to give it a claimed extra15bhp and at a later date i would like to run nitros as well which i can rig in with the injection stuff good luck with your prject i do recon it worth the effort as i was chating breifly with a guy with a beach buggy 1.7 8valve engine and gaswho had blown his diff with the power of the engine i bet the 16v got a lot more power than the 8valve .once the cars on the road may build up a second engine and look at making it turboed those nova boys better watch out at the traffic lights cheers steve,,, let me know how you get on ,,,
