Jake, would this be a good combination?
Guest
I am considering many different possibilities on how I can rebuild the 2.0L in my 914. If I rebuilt the motor but bored out my stock cylinders to add the 96mm KB pistons and left all of the other specs stock (i.e., compression ratio, camshaft, all the d-jet components etc.), would this be a good combination as long as I increased the fuel pressure? I ran a simulation of this combination and I picked up 1hp and 5 ft*lbs of torque over stock ...
Guest
Guest
Guest
- raygreenwood
A simulation will show you nothing accurate with reference to D-jet...on a non-stock engine. The way in which D-jet tracks to the vacume signature of an engine...is not exactly the same as a MAP sensor. There are other variations and variables involved. Even the factory best settings were rather under-tuned. A simple bump to fuel pressure will give correct volume...but probably not correct throttle response.
D-jet is very capable of doing much better than stock, but many of the adjustments are subtle...and take a decent amount of testing. I can easily get 5 hp and about 3 ft lbs torque out of the bone stock 1.7 , with FI tuning alone. With tuning, fuel stabilization, mild porting, slightly larger valves and aweb #73...I can get about 20 hp more than stock. Ray
Guest
Understood, but a simulation is a place to start. Jake, can you confirm (or deny) from your experience that adding, say, a Web 86 cam to an otherwise stock 914 2.0L motor (7.6:1 compression ratio etc.) would actually result in a decrease in hp and torque compared to the stock output?MASSIVE TYPE IV wrote:Simulations are just that!
There is no replacement for doing it and dynoing it- OR doing it and driving it!
I simulate alot of things, over half of it don't work.
Guest
