fan blade reduction
- synthesisdv
fan blade reduction
before we balance the rotating assembly, I wanted to remove some blades from the fan.
I have seen them anywhere between 4 blades, 12 blades, 20, etc.
Any suggestions?
thanks,
dr
Any suggestions?
thanks,
dr
- synthesisdv
- synthesisdv
- Class 11 streeter
- synthesisdv
On the street it will increase temps till you are running 5K. Also the F Prod cars run tighter gearing and the engine has less load applied than on the street. This helps with cooling.
On Marks FP car he is running his DTM at only 1.24:1 drive and the engine won't go over 325 unless he is in fifth and on the straight then it hits 350 for a second... with the 911 fan it was running 375-400 all the time!
- lmcchesney
Where is the crossover of reduced engine load vs increased air flow and less cavitation by removing teeth?
Remove one tooth per sector?
Thaks,
L. McChesney
[email protected]
Thaks,
L. McChesney
[email protected]
- synthesisdv
- raygreenwood
Ok...here is an odd related question I have been wondering about for some time.
What if you reduced say every other blade for the street...then added an outer set of "stator" type blade like the type 3 fan combination has?
Also, he 4 main posts on the type 4 fan that hold the alternator pulley ring to the fan...could be "faired" better...maybe extended to be slightly longer towards the center of the fan. Either way, they should offer less resistance and turbulence to incoming air.
I have been speculating on machining a type 3 outer fan pulley to be bolted onto the outer end of a type 4 fan just to see what happens. Ray
