Thermostat compatibility?? T.1/T.4
kgeil
Post by kgeil »
Hi, can I use a type 1 thermostat in a type 4 motor. I have a type 1 on the shelf, and the type 4 ones have gotten quite expensive.
Thanks for the feedback
Post by MASSIVE TYPE IV »
won't work.
Eaallred
Post by Eaallred »
Unscrew the tip of the thermostat, feed the cable through it, then screw it back on. It will work perfectly.
I just modified the new mexican style T1 thermostat to work on my T4. I'm toying with the idea of making a handful of brackets and modified new thermostats, but don't know if the demand is there.
Eric Allred
1963 "Street Legal" Drag Bug
MegaSquirt 3 Crank Fire EFI
Volcano
Post by Volcano »
They worked for me after I soldered a new cable onto the type 4 fitting.Beefed up on trhe cable while I was at it.Regards
73notch
Post by 73notch »
so it will work.......?
Eaallred
Post by Eaallred »
Did you read my post?
Eric Allred
regis101
Post by regis101 »
I'm in for two
73notch
Post by 73notch »
well, jake sounds pretty sure that it dosnt work, and he builds them for a living. jake, how come they wont work?
Eaallred
Post by Eaallred »
Oooo-kay.
Eric Allred
JohnConnolly
Post by JohnConnolly »
Weve been doing them for over a decade, and Eric Allred has one ON HIS BUS RIGHT NOW (1979). We have a kit for $60 includes the bracket and thermostat if you want to see for yourself.
John
Aircooled.Net Inc.
73notch
Post by 73notch »
thanks for the info eaallred, btw, nice site.
Guest
Post by Guest »
Could Jake be wrong?!?!?!
