This engine has a new port design that HAM and I have ben working on, the port velocity is amazing and the mixture was awesome! The sucker loved just 20 degrees of advance and thats where it was when it made this power with a little tiny 135 main jet!
As an example the last engine I did like this was much more peaky, and not as torquey, it needed 30 degrees of timing to make this power, and a 145 main jet. The combo was exactly the same except the port shapes and flow.
Once again, we bumped it up and heard it thump! This one goes down in the record books!
BTW, you should hear the throttle response! amazing! Thanks Len for all the hard work on this design!
The key is power right where you use it, thats exactly what this one was able to do!
