Billet Lifters are here!
Post by MASSIVE TYPE IV »
Okay, here they are!! This is the first pair of "Pro Extreme" lifters that we will be testing.
And YES Type I "Pro Extreme" lifters are in the works!!!!!
Starting tomorrow we will have a HUGE lifter test beginning with the following lifters all ran against a Web 494 cam with 3 different spring rates. This test will run 50 hours in the spintron and will give us real time data about what works and what don't on the same cam. I already have 13 camshafts ran with different sets of lifters but this will be the first big comparative test so far.
The lifters being tested will all be right off the shelf with no rockwell testing being done to them prior to the test- just like if a customer were to buy and install them unknowingly.
I will be testing the following lifters simultaneously:
*Our "Pro Extreme" lifters
*Web Cam two piece lifters
*Scat Lube a Lobes
*Brazilian OEM replacements
Each lifter will be ran on opposing cylinders and will share a camshaft lobe. There will be a 10 hour test with stock springs, 10 hour test with single H/D springs, and 10 hours with dual springs with 3 different spring pressure from them at 10 hours each. The last test will be about 400 pounds of tension over the nose.
Between each 10 hour round of test the lifters will be removed and measured and pics will be taken of the faces of the lifters. All data will be logged.
These lifters are 100% billet and are made from a chunk of round stock that is hardened BEFORE the machining processes begin! This means that unlike the chilled iron lifters all lifters in that batch have the same hardness. This procedure is very time consuming and hard on tooling but its the only way that these lifters have made the "grade" in their normal alpplications of 9,000 RPM 500 mile race engines.
The faces and bodies of these lifters are polished to a 50 millionths roughness average and are absolutely amazing to look at. The same polishing will be available on my custom web cam grinds to reduce friction even more and enhance compatibility as well.
The lifter is a two piece design with a removeable lifter cup. The lifter was made this way (just like Winston cup) to be able to be cleaned and also so the lifter could be lightened to the point that it has been. The pushrod cup is tested up to 1400 pounds of spring tesnion and sits on a shelf machined into the lifter and is held in place with a Tru Arc circlip.
These lifters are 70 rockwell and require no break in at all. Our testing will be done with zero break in as well... The faces of these lifters have been proven over and over again and the guys that worked with me to design them are amazing.
Now for pricing, expect these lifters to hit the market with a 350.00 price tag. My first run will be 20 sets and I'd like to get names placed on those as soon as possible as I will make the first big order after our testing is finished.
Some people may think that this is alot of money for lifters, and that Ceramics are just a hundred bucks more... Ceramics are the ultimate in lifters, BUT the supplier cannot keep us supplied and he is very hard to deal with.
These billet lifters should kill all our bad lifter problems. I will be testing the hell out of them to see just how they do wear! thats why I built the spintron! I have put alot of design time into these and I'm sure it will pay off- after all their normal application is 500 times more rigorous than any "Normal" Type IV or TI would ever be..
FYI, For those of you that watch Nascar...... These lifters were in 8 of the top 10 cars that finished yesterday..... The Winston Cup version is only .040 larger than these!
Last edited by MASSIVE TYPE IV on Fri Jul 23, 2004 5:16 pm, edited 7 times in total.
Plastermaster
Post by Plastermaster »
NAAAAA Too smooth! How yer ever going to wear out a cam with those. :D
Seriously, If a fly landed on one it would slide off!
Ron
Muffler Mike
Post by Muffler Mike »
that looks more like some serious Bling Bling fancy polished/chromed bolt on part. and you wouldn't even get to see it.
Yep... The finish is part of the key!! Thats the manufacturers biggest problem with all of the test lifters I sent him- the finish.... That polishing takes alot of time and money to do and equipment that our industry can't afford to buy.
The testing will tell..... after 50 hours we should know exactly what they will do, as well as the other 3 sets in the same fixture...
fortyeye
Post by fortyeye »
Ok ... I'll wait :x
You Type 4 guys have all the luck! :wink:
Dave
dstar
Post by dstar »
Ok ... I'll wait :x
Dave
:shock:
BUWAHAHAHAHAHAHAHAHAHAHAHA!
Type 4= 4 TIMES as expensive!
:wink:
Don
Not this time Dstar...
The TI lifters will be the same and maybe a bit more expensive than the TIV!
The reason being that the mushroom style of the TI lifter requires a larger chunk of billet to start from and requires more machine time to whittle down to size.....
sparkmaster1
Post by sparkmaster1 »
Have you been slacking?? Your hands and fingernails are way too clean!! Nice looking product. Tim
Owner Tim's ACVW Engine/Trans Service
fortyeye
Post by fortyeye »
Yeah we feel like mushrooms ... waiting in the dark ... red-headed step children ... 2nd banana ... and then we have to pay a premium for it. But we wait ... patiently ... tails between our legs ... cams flattening hither and yon ... sorry ... what were we talking about?
Dave
Tim,
I haven't been slacking... Just doing a different kind of work....
Its kinda hard to get dirty when all you do is assemble clean parts.
Honda's Killer
Post by Honda's Killer »
quick question. You said you will be running 2 different lifters on the same lobe. Opposing lifter bores?
If you put a scat opposite a billet, and the scat takes a dump, OR starts to mess up the lobe...
CompTurbo.com, Lucas Oil, Pacific Customs,
Nope, they will be ran on opposing sides of the engine- On the same lobe...
turboteener.
Post by turboteener. »
Jake, can these lifters be used on different cams without failure? If I am going to drop 350 for a set of lifters I want to be able to change camshafts like I do underware otherwise I might as well go with ceramics.
Yes, these can be swapped from cam to cam just like ceramics according to my manufacturer... They can also be rebuilt and repolished 8-10 times before needing to be replaced.
This is not a replacement for a ceramic- but it is very close and less money...
Honda's Killer
MASSIVE TYPE IV wrote:Nope, they will be ran on opposing sides of the engine- On the same lobe...
Ok so what happens if a lifter starts to wipe out, or the lobe. Will the other lifter be taken out as well
Locked
