Removing broken head studs ?
Posted: Mon Jul 12, 2004 3:22 pm
by Danny
Two of my head studs are broken. The one above the #2 cylinder, and the recessed one above the the #3 cylinder (broke deep inside).
I tried removeing the one above the #2 cylinder by welding a bit on the end and using plyers/sokets to remove it, but that didn't work.
What do I do?
Posted: Wed Jul 14, 2004 6:31 pm
by cnavarro
Since you're in SoCal, just to go rimco. They can have them wire edm'ed out for a few bucks. I've sent porsche 356 cases to be serviced, since their studs rarely come out. Nice work, only one case saver required after 3 cases.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Posted: Sat Jul 17, 2004 7:13 pm
by mike@crosbys
any competent machine shop should be able to get a broken stud out, they aren't that big of a deal
Posted: Sun Jul 18, 2004 3:01 pm
by Guest
I bought a broken stud/bolt removal set and got the one that broke flush with the case out. I'll have my mechanic re-tap and replace the two studs. Thanks
