cleaning engine
mrgizmow
cleaning engine
low oil pressure suggests that it is time to remove the engine that is currently in my Baja Bug. I have a spare that I picked up at a local wrecking yard. It seemed to start and run ok, but when I removed the stock oil pump to replace it with a larger unit to push the oil up into the extra cooler (for those hot N. Calif. days in the mountains) I noticed that the inside (timming gear) looked pretty gunky. I do not expect the engine will be used more than a few months, but it still bothers me to fire it up knowing it looks this crudy inside. Before install, I was thinking of sloshing a couple of gallons of solvent in the block a few times to rinse the bulk of this stuff out, then running the clean oil thru the inline filter. Do you think this would cause more harm than good. [b]Any suggestion........... ?[/b] Thanks, Gerry
Guest
cleaning the engine
Thanks Marc:
Solvent is sloshing around inside the case as I write. I do have a full flow, drilled and tapped a couple of days ago. I will flush with deisel a couple of times and then add a cleaner to some 30 weight oil. Given this day and age, I was surprised at the muck that appeared built up on the inside stuff I could see (timming gear). It kind of reminded me of those days when folks only had non-detergent oil. It is hard to imagine that anyone would have been running this stuff for 40 years. I hope it runs through the summer.
Thanks again....... if anyone else has any advice on flushing the inside of an engine,,,, I'm interested in hearing......... Gerry
