VDO Gauges
bmorganchico
VDO Gauges
New, in the box Tachometer, Voltmeter, and Cylinder Head temp gauges. Also, slightly used Oil Temperature and Pressure gauges.
Make offer.
Make offer.
bmorganchico
- John Kelly
Does the cylinder head temp gauge come with the wires that connect to the sender? How much do you want for it?
John www.ghiaspecialties.com
bmorganchico
- John Kelly
I was asking about the wires that connect the gauge and sender, not the sender. I've found some finally, so thanks anyway. Didn't need the gauge unless it was complete with all the wiring and cheap (insert frugal emoticon).
Thanks, John www.ghiaspecialties.com
britegreenVWSB
Re: VDO Gauges
Nevermind. VERY old thread.bmorganchico wrote:New, in the box Tachometer, Voltmeter, and Cylinder Head temp gauges. Also, slightly used Oil Temperature and Pressure gauges.
Make offer.
- dstar5000
Re: VDO Gauges
HAHAHAHHA, I need some guages, do you still have `em for sale?
Don
Don
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
- dstar5000
Re: VDO Gauges
Only 8 years old at last post!
