Spark plug wire hole location(s) in the DTM
Alaskabug
Post by Alaskabug »
I'm scratchin' my head trying to figure out why the plug wire holes in my DTM shroud aren't aligning with the direction of the plugs in the cylinder heads. It seems my plugs point more horizontally toward the intake manifolds than the holes that are pre-cut in the shroud in an almost vertical position on top of the head area. I might be able to get 90 degree plugwire ends to fit on the plugs and work ok, but it will be a real pain in the butt to change the plugs (read impossible). My heads are (supposed to be) 2.L 914 heads. What's up ???
Cloudbuster
Plug location for DTM
Post by Cloudbuster »
Just guessing.
914 2.0 heads have a different plug angle/location. These require longer plug wires (which took me 3 tries at different stores to get right :x). The 'more horizontal' description of the plugs makes it sounds as if you have 914 2.0 heads, but the plug holes in the DTM are cut for 1.7, 1.8 (or 2.0 bus) heads.
Alaskabug
Post by Alaskabug »
Thanks Cloudbuster, you have confirmed my suspicions.
Hmmmm...., looks like I'm going to have to relocate the holes to the correct location for all 4 plugs then figure out a way to plug the predrilled ones so the shroud still looks good. I understand Jake built the DTM to fit "most" applications (heads) but too bad I have to make this modification.
Longer wires will allow me to connect to the plugs, but won't help when it comes time to replace them.
Thanks for your feedback.
Alaskabug.
Mark the canuck
Post by Mark the canuck »
You can plug the old holes with a sink drain block off available at most hardware stores.
You will have to redrill your plug holes, there is a measurement off of the 3 bolt holes, email RAT for the spec.
Alaskabug
Post by Alaskabug »
Thanks Mark, I'll e-mail RAT for the specs. (Rubber) sink drain stoppers? Hmmm..., I'd prefer billet plugs. I'll see if I can get a local shop to make some nice looking plugs.
Thanks again,
Alaskabug
Mark the canuck
No...the chrome block off plugs.
Sorry I meant they are used mainly for the unused taps.
Look at the DTM on the main DTM page at RAT...that's what they are.
Alaskabug
Post by Alaskabug »
Found it Mark, looks good. Thanks again for the suggestion.
Alaskabug
'56 Bug TIV 2056 DTM
davygrvy
Post by davygrvy »
Mine don't line-up either.. no problem..
:twisted: DREMEL!
speedy57tub
Post by speedy57tub »
Well the good news is you have the better and more preferred 914 2.0 heads. Like mark said, you can use the chrome plumbing covers. Get us some pics when you are done! :wink:
Frozen Goat
Post by Frozen Goat »
Well, I guess the question (that only Jake can answer when he gets back) is can the DTM shrouds be produced with no spark plug access holes in the future so the customer can locate them on their own according to which heads they have??? :roll:
germansupplyscott
Post by germansupplyscott »
Frozen Goat wrote:Well, I guess the question (that only Jake can answer when he gets back) is can the DTM shrouds be produced with no spark plug access holes in the future so the customer can locate them on their own according to which heads they have??? :roll:
i can answer that - YES.
we sell the DTM in canada, and yes it is made with no holes to begin with, the holes are machined in after the molding process. i have a DTM shroud in our shop that has no holes. it is going on an engine with 914 heads.
Frozen Goat
punkinfair wrote:yes it is made with no holes to begin with, the holes are machined in after the molding process.
Scott, thanks for answering that - I'm sure there are alot of folks breathing sighs of relief (including me - as I plan to pick one up this winter - and yes, I'm using 914 heads). :D
speedy57tub
That's 914 2.0 heads! 914 1.7 and 1.8 and VW 1.7, 1.8 and 2.0 VW heads have a different plug angle than the 914 2.0 heads. I just want to chime in to clear it for those who aren't aware of the difference. :wink:
germansupplyscott
speedy57tub wrote:That's 914 2.0 heads!
yes, quite right.
germansupplyscott
Frozen Goat wrote:Scott, thanks for answering that - I plan to pick one up this winter - and yes, I'm using 914 heads). :D
let us know when you are ready, we are the canadian distributor for the DTM. we have them in stock!
Locked
